Renny 5
Im using Clio 172 hubs. They’re literally beefer version of the gtt hubs. Only issue being is that I had to use a mix of Clio 16v/gtt shafts and a Clio 172 coupling. I guess the offset on the inside of the hubs is greater than the gtt hubs??Which front discs did you use? 5 gt turbo list 20mm thickness new and 172 24mm new
Never got close to 172 calipers on the 5 but could it be this? No idea on hub mounting position with 172 calipers?
Looks much better sprayed![]()
@Turbell this is the guide that I used… seems to be used by a lot of other guys I know that have done the same conversion:
Renault Clio 172 sport conversion into a R5 GTT Guide
renault5gtturbo.com
There’s a handful of ways todo it depending on skill and cash flow. Regarding the ecu and loom… if youve got a ph2 loom then you need to use everything on it including the uch! I might be wrong but the ecu, barrel, key and uch have to be off the same car otherwise it won’t work (this is in case you’ve bought just the loom, ecu, barrels instead of the whole car and they might not be a matching set) everyone I’ve spoken to has used a ph1 loom as it don’t use uch. If your shit at wiring like me then I suggest you send it off to someone like beaniesport. He did the loom on my meglio and I’ve never had an issue and everything works perfect
