DaveL485
Staff member
Ignore my last post, you need a front, OE Renault 5 driveshaft outer joint to go in the hub, right? I suspect any R5, 9, 11, or 19 one will fit, probably most lower spec clio models too, you can knock the ABS ring off if it fouls. You should be able to find what you need at any local scrappy. Avoid RS models they tend to have a larger spline.I misplaced a drive shaft end for the front hub and need as drive shaft end (hub end) if anyone around London has one for sale.
