Had enough coupons in the sausage ration book today to have another day in the garage working on the 11 and had a productive day!
First I fitted the uprated R19 16v Hub & Brake assembly onto the offside:
Then I started work on fitting the new R19/Megane rear Engine Mount to allow me to fit the power steering rack. I took a picture of the Renault Part Number of the mount for you good people if any of you would need one of these mounts in the future for a retro-fit power steering project of your own:
The rubber engine mount can easily be obtained from motor factor's & e-bay, but I had to modify it slightly to allow it to fit onto the R11 Subframe by removing a small locating nub, and sawing a lump out of the rear bracket:
You see that the new engine mount gives adequate clearance for the power steering rack pipes:
The next job was to have a go at swapping the rear axle from the 11 Turbo item, to a R19 16v one I found for wider track. Thanks
@Adeyspec for giving me the idea for this modification. I took a load of pictures to show the differences. You can see that the fixing bracket on the R19 16v Item does not have the bend in it like the 11 Turbo item:
There is roughly 50mm wider track with the R19 16v axle:
I tried to take a couple of comparison shots of both axles on the car to show the difference, the R19 16v axle certainly makes the wheels fill the arches better.
Thank you for reading
