Clio Big Steve's RB Clio 182 Cup Restoration
Bloody rusty Renault's.. who'd have them eh?? :help.gif:
Was having a pick around the underneath of the rear of the car, checking that I'd not missed any scabs that needed attention before I packed away the underseal kit, and removed the fuel filler neck to give me better access to the rear offside arch. After I'd removed the neck, I had a closer look at the fuel door area, and saw something that caught my attention...
Tried to undo the bolts, but that wasn't going to happen... so I ended up drilling off the heads of the bolts. (At this point let me recommend some Cobalt Drill bits to you guys, they;re bloody fantastic for getting thru this old French steel without any effort!)
With the bolts removed, you can see they were never going to come un-done:
With the fuel door off, I could see the grot a lot clearer...
I then removed the rest of the filler-neck, and had a pick round with my scraper:
There was a lot more than first thought:
More painting needed.... BALLS.. :punish.gif:
Thanks for reading :)
The rust converter had worked it's magic overnight:
So I gave it a little sand down with my small pneumatic Dual Action Sander to remove any knibs:
Then masked it up:
Before giving it a couple of light coats of zinc primer:
Will come back to this tomorrow.
The passenger door seal was next. It was a knackered thru a combination of corrosion bubbling up under the rubber:
...and getting bent when someone re-fitted it (badly):
So I replaced it:
Removed the masking tape around the fuel filler neck at lunchtime today and very pleased with myself at the results!!
I tried an old technique I learnt when I was painting R/C Body-shells of leaving the masking tape a little proud of the edge I wanted to mask, to help hide the line... and sure enough it worked a treat!!!
A jolly happy camper today :grin.gif:
Now the fuel neck is looking so spangly, I couldn’t go fitting the fuel cap back on looking so nasty:
I’ll be putting the fuel cap back onto the car with some flanged M6 Stainless bolts, so I won’t be needing the moulded-in bolt head retainers, so I cut them off with a nice sharp blade in a junior hacksaw:
Pleased with how they came out:
it was then a case of masking it up:
and a quick lick of paint:
Will see how that turns out..!?
Thanks for reading 🙂
Managed to smuggle some grey insert OE Halogen headlights to @jas_racing and he's worked his usual magic on them
During the headlight restoration, @jas_racing found that one of the adjusters inside the headlights had broken up. A common problem on Clio 2's as the plastic material gets brittle being next to the headlight:
Thankfully there's a fix using a BMW headlight adjuster that's available on eBay for a couple of quid, and as you can see, it's a near identical match:
@jas_racing fitted them to the headlights and now they're all ready to go back onto the car:
Been fighting with the front cross-member/radiator support for a few weeks now. Bloody thing was in shocking condition for a 2003 car! Looked like it had been at the bottom of the sea!! I've not showed pictures of the back of it, to hide it's embarrassment!
  • Stripped the paint off around the rusty areas
  • Then treated with Bilt Hamber
  • Then heavily sanded down to look presentable
  • Rust now converted with FE123 Rust Converter
Going to see if it will accept some paint this weekend...? :punish.gif:
Thanks for reading! :)
