Had a couple of cheeky hours in the garage last night and made a start on the HVAC system. Radiator and fan is already prepared and assembled, but I'd recently got hold of an AC condenser, so I thought I would fit it:
However when I look at the old one I took of the car, the black anodised brackets are all rusty & sh1te, so I masked them up:
And gave them a little lick of gloss black paint to hopefully stop the tin worm from taking hold:
Whilst I was in the painting mood, I cleaned up the throttle body, and gave it a bit of a spruce up too. Wire wheel to get all of the old crap off... then a lick of etch primer:
followed by a couple of coats of
Eastwood Aluma Blast paint:
Whilst sitting on a plane this week, I also tried to write a list of everything still left to do:
Remove front load bearing elements
Remove rear load bearing elements
Prep/Paint/Dress
- Prep main ECU Bracket & Powdercoat
- Blast, Prep & then Powder-coat front hubs
- Powdercoat rear axle
- Fit new bushes to rear axle
Fit components to front of car
- Front triangle sub frame Braces
- Pas bracket
- Driveshafts
- Gearbox Oil
- Front coil-overs
- Replicate/fit front to rear brake lines
- New front brake discs
- New Wheel Bearings
- Front Brake Calipers
- Front Brake Pads
Fit components to rear of car
- Exhaust heat-shielding
- Rear Axle
- ABS Sensor
- New rear brake discs
- Rear brake calipers
- Rear Brake Pads
- Rear Handbrake Cables
- Exhaust
Engine bay
- Alternator belt
- Spark plugs
- Spark Plug wires
- Inlet manifold with gaskets
- Engine oil
- PAS Fluid
- Thicker washers for Engine mount
- Positive power cable
- ECU
- Radiator air-con condenser & Fan
- Coolant Bottle
- Coolant hoses
- Refill coolant
- Air-box and cold air feeds
.....I was surprised how much is still ahead of me!!
(And I've not yet added the interior!!?)
Thanks for reading
