Bloody amazing how a day just flies by and this is all you have to show for it....!?
With the Brake servo all de-rusted and dried off:
Few coats of primer applied:
Then a quick rub-down with 180 grit paper:
Before a couple of coats of Gloss Black:
Think it looks better????
I also gave the brake lines a quick brush over with some black and green paint to bring them back to life. Little bit disappointed with the brush finish... but it's only a sodding brake pipe:
Last to be painted today was the two new wishbones I've got. I know from my Raider that the Original Renault Black coating is about as much use as s**t when it comes to staying put and putting up with a few years of British Weather, so I decided to add a couple of coats of additional protection:
First step was to roughen up the existing coating with a little dremel flap disk:
Then prime:
Then a couple of coats of Gloss Black again:
Crazy to think I've ended up with that I started with... but I know these will stand up to the weather a lot better now. (Bit more paint applied since I took these pictures)
Thanks for reading
