when I know ill post up on hereGreat job and numbers
How is the weight of Twingo with f4rt?
Do itI just bought a Modus with the 1.2 Turbo GT engine... next conversion Adey?
Do 172 cups have a slightly wider track on the front? Do they run a different subframe?So back with a little bit of work on the car, namely looking into the driveshaft issue I have/had. I was unsure if my driveshaft was knackered or if it was bottoming out under compression, removing camber and raising the ride height 5mm seemed to cure it..... Whilst chatting with Chris he suggested checking how much free play there was in the shaft by simply removing the hub nut and tapping it back as far as it would go until it went solid, he had measured an average of 20mm push back on factory cars and he works with that figure when making custom shafts for the drag car. I gave it ago on the side i have an issue, and i only measure 6/7mm before it binds up and stops moving. Now this is an issue as I'm running pretty much 0 camber currently, the factory alignment asks for near 1 I think and I generally have about 1.5 neg for spirited driving and getting out of corners. Adding this back in will push the driveshaft in more causing the issue again...
So I need to do some investigation, see if there's some combo or some machining I can do without having a shaft made up for it. Maybe there's a way I can push the wishbones out a little to gain some width, I seem to remember someone making elliptical wishbone mounts. Need to put my thinking hat on to get it done the PMT way.
i think they may have had the wishbone mounting points a bit further outDo 172 cups have a slightly wider track on the front? Do they run a different subframe?
That'll certainly help.i think they may have had the wishbone mounting points a bit further out
EDIT, a quick google shows them having the wishbone point 8mm further out
...yesSo I've done some bad maths and I think I can gain and extra 12mm of plunge by swapping the cup and spider off the GT shafts to the DCI/172 shaft on the drivers side. If someone could agree with me that would be great lol
compared between the 2 the GT cup sits 5mm further on the shaft to start with, it then has a 10/11mm deeper body/engagement. The spiders gears themselves are 6mm bigger so half that difference for max depth.
5mm + 10mm - 3mm = 12mm correct?
Does this sound right, my heads fuzzy today but I think it works? So I just need to get access to a press to remove both cups and put the GT cup back on the DCI inner half shaft.
This would save making and running welded/modified wishbones though I'm not actually that bothered about that as the wider track would be beneficial
View attachment 155319View attachment 155320View attachment 155321View attachment 155322View attachment 155323
Sticking to form, bodge it and cross fingers!So I'll bosh the deeper cup on the longer dci shaft, bish bash bosh sorted
Hopefully
worked well so farSticki
Sticking to form, bodge it and cross fingers!![]()
