Duncan Grier
2.5hrs of garage fun can only mean one thing.......loads of pics & minimal progress
So got on with top wishbone positioning ready to get on with cutting etc......only to have a Houson moment.....
Now they were definitely level when I welded in the front bottom pickup
so spent some time after double checking shell still level went through solutions, settled on shimmimg the rear subframe down by 4mm both sides and spot on. Having the front top wishbone pickup at correct postion meant this did not mean having to redo......
On reflection I can only assume with the subframe on and off mutliple times may have failed to tighten up the rear
Have lots of adjustment for caster, camber and height so feel no real harm done other than troubling my over active
So then got on with top wishbone and happy with initial test positioning. Decided want to do the other side front top wishbone mount before making permanent
This will just help me get another reference point that it true to avoid having wishbones on the wonk...
