Which battery tray option
    Votes: 0 0.0%
    Votes: 1 100.0%
    Votes: 0 0.0%
  • Total voters
    1
  • Poll closed .
Saturday consumed with painting neighbours garage floor with him and half a day helping a friend with his barn conversion.....thoroughly knackered had beers and more beers for good measure.
After 2nd coat of garage painting early this morning and family time and garden jobs got 3hrs credit to get in the garage just 😀
I'm interested to know why you're not butting the two pieces tight? Leaving a gap makes it harder to form a pool which you can then pull ( or push depending what you prefer/access ) or this a method you've used before or been advised is best on a butt weld ?
I make no claims ever to be a pro/expert welder but welding into a void is always harder?
I'm sure @Mark_L will know far better than me, but a tight butt will let you use more juice , flatter weld?
@Turbell I am def more in the novice scale of the group so welcome all the good feedback
Went with that method for good use of the clamp inserts to reduce movement and control any movement with little bit of hammer and dolly
Was not too bad other than having to go revisit inside.....again maybe more power would have avoided
Guess experiance also but found interesting the change of characteristics from welding flat on bench v vertically on car....should have rotstimg the rottiserie lol
I use strong magnets if I can't get clamps in, turn juice up for tacking, middle of section out each way, then drop power for runs, best bit of advice I got was the need to create the pool , then drag or push it along, don't get me wrong I usually start with the best intentions and it can turn to shit, so much to get right for a nice, good looking weld.
I hold the neck sometimes as well if I can't get a good rest on something, otherwise I end up waving the torch about like a piss head and his prick on a Saturday night....
Whip heads off tacks as well, then when you run up to them you won't have as much extra metal to add to the weld you've created.
I reiterate.... I'm a reasonably capable idiot, I make no claims to being good at it, I know my trade , but welding, cars even, ain't it.
I find having a gap gives more penetration with less heat so even though I use more power. Gives less distortion. Tig welding is different, Need the heat so no gap is good.
The clamps hold the position well too. The other issue is they gap tend to tighten as you tack it up so no gap can sometimes end up in an overlap at the other end. Can sometimes stretch a tack with a hammer and dolly.
