I spent Sunday morning at Silverstone, went on track in this thing, which was awesome
Had a great hoon out in the Vee, which is now filthy, then back in the garage in the afternoon. Decided to drop the axle complete, to make it easier to deal with the various rusty bolts and stuff off the car.
Drained the diff, good to see the oil I put in it ages ago was still nice and clean.
I undid the rear shocks at the trailing arms, but left the bolts in, undid the rear centre diff mount, then supported the diff on a jack and rattle gunned out the enormous axle crossmember bolts - thjis is one next to a standard size wheel nut.
Then as the axle dropped I had really good access to the brake lines, as usual though everything rounded off so out came the cutters. Even after that with a hex socket they rounded so I had to cut everything away with a grinder. I got the flexis out in one piece, not that I will re-use them but I can use them to size up for braided lines in the future.
After they were off and the diff lock plugs and pipes were removed I put the wheels on, knocked the shock bolts out and dropped it on the floor. I removed the coil springs and a couple of plastic shields (rotten screws again)
and just rolled the whole axle out the back.
I also noticed whoever fitted the rear shock many moons ago left the original packaging strapping on the top... I mean, how lazy is that? These seem to be in decent nick despite the age but I see a coilover replacement in the future plans
