DaveL485
Staff member
Hi Ironman, I used the EM121 epoxy paint on the underside, wheel arches, interior and engine bay, this has a glossy finish to it. I then used the EM421 epoxy primer on the outside of the shell, wings, doors, bonnet and tailgate. I followed this up with high build primer and then a wet on wet primer prior to top coat! Hope that makes some sense!Sorry if this is been asked, but you say you used EM121 all over the car as the primer sealer. I see this is normally used for Chassis work? and EM421 appears to be recommended for use on panel/bodywork. So what made you choose the 121 to put all over?
Oh shite!!! Thanks @Mark_LNot seen this thread for a while..
Come a long way, good work Chris!
Just a little point, this type of joint is a no go on brake lines. Need a double ended joiner between because they basically crush together restricting flow.View attachment 209100
Makes sense now! I thought you just used 121 all over. You been happy with the results of it before the paint? Good to work with?Hi Ironman, I used the EM121 epoxy paint on the underside, wheel arches, interior and engine bay, this has a glossy finish to it. I then used the EM421 epoxy primer on the outside of the shell, wings, doors, bonnet and tailgate. I followed this up with high build primer and then a wet on wet primer prior to top coat! Hope that makes some sense!![]()
Yeah, I am really happy with it, I am a complete beginner to all this and managed to get it out of the gun and on to the car with reasonable results. I struggled more with the high build primer than any of the other paints I used!Makes sense now! I thought you just used 121 all over. You been happy with the results of it before the paint? Good to work with?
Thanks @Big Steve - Raider, I’m just bumbling my way through it!This is such a fine example of a 5GTT @Chris74# and for someone to create this who is relatively new to the scene is a real credit to you mate!!
Yes me too...Ooooh, i'm on the fence with the body coloured wheel centre!
@Brigsy i did wonder why there were two horn types!! Just putting back what was there before!How come both oem airhorn and aftermarket horn? The oem air horn is loud as when working right. I used to love it for the comedy factor
