If they are the same brake clips as fitted to 182 brake hard to flexy lines, then they are the same as the BMW ones here:
Hope that helps
Hope that helps
Burton upon Trent mate.Spot on cheers mate. Im in Redcar, where are you based?
Hi @clarky_gtt - 2x M12x170mm & 2x M12x 140mm - Both 10.9 Grade with M12 Flanged Nylocs - I went for A2 Grade Stainless Steel just because of where they sit! Slight difference with these is the bolt head size, Mine are a 19mm head as opposed to the original being a 17mm head. I just have to file out the clip bracket that goes over the top of them.Any chance you have the sizes for the rear axle to body nuts and bolts? Only ones I didn't get new as nla
If you want the beam, come and get it, I have a campus beam I can put on to roll the van off to the scrappers!!I'm absolutely resisting saying I want that extra beam for Camprust , because I'm absolutely not going to do anything with it.
I have in no way had a tape measure out today on the 225 and looked at how the engine would fit.
I'm starting nights today, so I'll be zombie-fied in the day for a bit, but yes, I'm interested in the beam, sort of forming a plan for Camprust if it stays, but I'm not shouting about it yet as I really don't have the mojo ATM.If you want the beam, come and get it, I have a campus beam I can put on to roll the van off to the scrappers!!
Don't use stainless on load bearing suspension, it's not the right tensile strength, you need 10.9's.with new stainless bolts!
Kebrell's, yes used them for ages, yes they moved and from lockdown 1 they stopped dealing with public/over the counter@DaveL485 cant remember the name of the place/guys but one at bottom of humber road in Stoke by the bridge, used to be my no.1 place to go - was fantastic....think they might have moved upto a unit by Canley/Tile Hill if still trading?
The materials used to make steel stainless inherantly make it weaker, It's basically down to tensile strength where fasteners are under load. You'll see the markings on the bolt heads.@DaveL485 looking at the post @Chris74# has used 10.9's just in stainless flavour
So, just checked the invoice from Westfield fasteners, the longer M12 bolts are BZP 10.9...saying all that it looks like its a plated 10.9 anyway when I zoomed in (does that say 10.9?), so I think it's OK. Just remember kids, dont use stainless fasteners on load bearing components
