Nuts & Bolts???? This little lot cost £85?????
Still they will look the part when they are on! I managed to get out there this afternoon and got straight on with changing some of the rusty bolts for new!
and this one
and new washer on this one..
I then had to get the calliper back off as it is the wrong hand, it came off nice and easy and I painted the link plate for the calliper bolts!
Then on with the correct one! Handbrake at the bottom!! thank you
@Duncan Grier
I then got the pads back in but still couldn't work out how to get the anti-rattle springs in!! FFS!!
I bodged them in but knew they weren't right, then had an absolute nightmare trying to get them off! cue spring flying off and being at large for a couple of hours!
I left it and carried on! I cut a length of old brake pipe that I had saved and decided to use it as a template, after watching a you tube video on flaring brake pipes, I got to it!! I had a moment where I had to mither
@Duncan Grier for some support as I was still unsure of the calliper, as the Haynes manual was confusing the life out of me! look at this!
Anyway on with the brake pipes! I made my template and then got the new pipe out!
I also got the new hoses out just to try and work out how it all goes together!
I also found the new clips for the brake pipe to rear beam! I got these part numbers from
@Big Steve - Raider 's Renault 11 build! Thanks!!
I got on with straightening a length to suit my template!
Not a bad tool that straightener (for a tenner!) I then put my new found flaring skills to use!
I then formed the new pipe to suit the template, only straighter!
I then fitted the clips to the beam and got my new pipe in place!
I then realised that I need some saddle clips for the hose connections, I thought I would just order some new ones, but £20 for two??? FFS, people really take the piss!
I had a dig around and found my minging ones and put them through the sand blaster, then primed, painted and lacquered, them....
Whilst I was doing this, my son came in and asked what I was doing, I proudly took him around to show him the fruits of my labour - he comes straight out and asks "where are your anti-rattle clips?" I explained to him that I had tried a few times to get them on and they had since flicked off and are somewhere on the floor. He consulted the manual and came back and showed me where they are supposed to sit! I picked one up off the floor whilst expressing my deep disgust for these clips and showed him how they do not fit.....whilst doing this, the bast**d thing popped straight on! I then spent 10 mins searching for the other and did the same. My son left the garage with a very smug grin on his face! shabackanackafackanacka!!!!
I then got the handbrake cables out whilst the paint was drying to try and get my head around them! and their route up the car!
I hooked one over and left it at that......paint drying, heading in for a rest!
Thanks for reading guys!
