Adamthomas73
Looking good!
Looking good!
Whaddya think I am, your clip bitch or something?@DaveL485 another clip for you to identifyThese ones hold the plasic trim in place along the sides, and are an absolute pain to get out.
Ha, awesome find, cheers! Now to ponder over whether its worth it....just need 2 clips, but you cant tell!!Whaddya think I am, your clip bitch or something?
New ** RENAULT 5 GT TURBO REAR QUARTER TRIM LARGE CHRISTMAS FITTING CLIPS X 6 | eBay
Find many great new & used options and get the best deals for New ** RENAULT 5 GT TURBO REAR QUARTER TRIM LARGE CHRISTMAS FITTING CLIPS X 6 at the best online prices at eBay! Free delivery for many products.www.ebay.co.uk
Does your gauge do level only or level and pressure?
If both, then there are three sensors, a level sensor, a pressure switch (this changes the dash gauge function from level>Pressure when it detects oil pressure, and the pressure sender which feeds the gauge when the switch is on.
Thanks for the suggestion, doesnt seem to have made a difference though ... will pursue checking connections though.What does the main engine earth look like?
Try a jump lead from the gearbox to the battery earth and see if that helps.
If not then check the battery main lead for poor contact
Its a new battery, 9mo maybeNo problem, I had similar once and went deep diving with no luck, turned out the earth lead was toast.
how old is the battery? Might be worth getting it dropped tested as it may have become unstable
