I did wonder given the size, 45 days till its supposed to be on track (albeit a mini meet at Curborough so only a couple mins sprint at a time) and got a lot to do so might slap it in for now and send it and deal with it later.Not sure how well the gtt rad will work on your setup mate. They are quite borderline on a gtt, with large fmic i had to go for the larger diesel radiator to keep temps in check. Id see if you can go for something a bit wider.
This car will be half yours at this current rate. Gutted I missed a guy on FB giving away two whilst I was stuck in LA with the rona, might take you up on it if I don't do the above short term.What you want is a 182 rad in there @CreweTube, I have one... make me an offerproven at 270+bhp and only started to struggle with high ambient temps and 300+bhp
Yep the rack was in the 50k region when i removed it im sure.
