An absolute colossal pain from start to finish, easily the worst thing so far on the car...
With limited time due to pregnant sick wife and having to do lots of childcare time has been limited to 15 mins here and there for last few months so this was a pain as nothing is achievable in that time, the rear beam capital bolts did their traditional fuckery which required them to be angle ground out which meant I've sliced the shell so need to weld/fill that back in. Luckily only inner skin and quite far away from the actual bolt holes but still a pain to deal with.
Old cruddy discs put back on and need to re-attach handbrake/ABS lines still.
Brake lines I've decided to run internally so will get some flexi pipes made up from caliper to bulkead (unless anyone knows any that will fit, maybe a set of front ones?) then run a line through car to front bulkhead and back into system.
