give him a nudge id be up for that, its only down the road tooVery good 60-100 mate, you need to race Stavs MR2, very similar performance.
My FD did a 3.7 but then grenaded itself 10 mins later so not sure it counts haha
add it as a custom measurement, its easily comparable to production cars then too. I find the higher speed stuff a little more "dangerous" to do tbhI didn’t see 60-100 times before… I’ve just been on dragy and it looks like it’s been updated since I last looked, Good time though![]()
I agree regarding the 100-200kph runs, just seems dodgy on road. Also funny how quickly you get used to the power you have and want more. Very nice times mate, great power vs £££ spent.So this morning was nice, dry but cool so I decided to try and do some pulls on the draggy. 60 to 130mph is actually very hard to try and do in any sort of safety, same for 100-200kph. I think ill stick to my normal 60-100mph (still silly but safer still) managed to get the following result from the records.
4.51 60 to 100mph isn't shabby at all, and id recently being thinking it was feeling slow....
View attachment 202856View attachment 202855
not something ive had, does it only happen it you clip it or its bounced a fair bit? what fuel setup do you run?Loving the big pullsHere’s a question for you though… do you ever get big ignition cut after banging it off the limiter afew times?? Sometimes I get it in the Clio and I don’t think it’s the map.
Sometimes it’s randomnot something ive had, does it only happen it you clip it or its bounced a fair bit? what fuel setup do you run?
if you have a read back through this thread (can use the search button up the top and tell it to search the thread for specific terms) you will find all the infomorning all. I’m wondering if anybody has mates a jr5 to a f4rt 787 if so how and what drive shafts we’re used
This is what happens when all the OE goodness of plastic shrouds and ducting is binned and not fit for purpose.No undertray? Man the second you get that on it will really, really help. Even if you have to fab one PMT style is thin sheet metal it will help no end.
I've added ducting to force air into the radiator but surprisingly renault only seemed to fit undertrays to RS models, and with them being rare to start with finding a tray off one is even harder.This is what happens when all the OE goodness of plastic shrouds and ducting is binned and not fit for purpose.
Glad you enjoyed it, high praise if its from youEpic conversion and thanks again for letting me take it out. Really impressed with the performance on low boost, must be a riot on high.
Do some CAD ( cardboard aided design ) and then some tin snips on thin metal? If your going full send put in a couple , or three NACA ducts in reverse ie vents facing the back to lower the pressure under bonnet further and force more air through the rad / intercooler.I've added ducting to force air into the radiator but surprisingly renault only seemed to fit undertrays to RS models, and with them being rare to start with finding a tray off one is even harder.
If I can't find one I may look at seeing if a clio item will fit
