Big turbo dug out of the scrap pile. I took it apart to make sure everything looked good inside and to drill and tap the compressor cover to blank a pipe off. Still might never make it onto a car but I was a little bored this morning.
thought about it but the stock turbo is so small I don't think there is much to gain high end where I want the gains. I want a turbo to flow higher up the rev range not deliver more torque at low rpm.
NA cam (older)
Lift : Inlet - 8,849 mm Outlet - 8,850 mm
Timing :10° 31° / 25° 8°
77 00 100 140
NA cam (newer)
Lift : Inlet - 8,004 mm Outlet - 8,850 mm
Timing :10° 24° / 25° 8°
82 00 664 673
Turbo cam
82 00 658 986
Just for future ref.
Also parts on the way, 4 bar fuel pressure reg to give me a tiny bit more scope from my injectors without slapping huge ones in and an R35 GTR fuel pump. My thinking is the GTR runs 2 of these and will do 600bhp all day long so one should be a capable of 300bhp, plenty more than i need.
