I thought it was time for an update! Got my car back on Friday - new steering arms and tie rod ends. Dave's adapters for the TRE's worked a treat. The car didn't track straight when I first drove it but seems to have settled down after a few miles' worth of driving. Need to take it back for the tracking to be checked again (they'll do it FOC).
All four tyres were older than 10 years, with the oldest being 13 years old. So maybe I have a bit of an excuse for losing it and crashing! I went for new Continentals, and so far the difference is amazing. It grips better and rides better and handles better, so a definite improvement.
I have managed to fit all the panels and lights I bought - I was very short of time on Saturday morning, so I kind of just threw the panels on and the lights in. The end result is this!
The bumper is currently held on with a bungee but it will do until I get a better used one. I'm really happy with the way it looks although the alignment of the panels could do with a bit of tweaking. The new nose cone looks so much better than the old. I hated the fact that it had been debadged!
The wing was bent at the bottom during shipping, so it doesn't line up:
... but this can be sorted when the car (eventually) goes to the bodyshop. I found quite a bit of rust as I was working on the car...
Strut top, notice the crack...
More worryingly, it's completely rotten under the VIN plate. It seems there is a drain tube that's just been dumping all the water down inside the inner wing. I think that's a potential cause for some of the rot:
You can see that the VIN plate has popped off! It came off as I was bashing the inner wing into shape. It's pretty straight now but I want to replace as much of it as I can. I'm pretty sure that the crack and the rot would be an MOT failure, so I definitely need to get it sorted and will tackle it when I replace (or get replaced) the strut top bearing. Parts are on their way (from Belgium) but delivery is pretty slow!
Inner wing is all wavy at the bottom (oops) as this is where the impact was felt:
I have also spotted some other rust holes:
And some crustyness at the join of the front of the inner wing. I'm hoping to get some solid sections cut out of a good car, but may end up fabricating something:
The intercooler is a bit mashed but it's in horrible condition. Great excuse to go for a FMIC! Anyone recommend a FMIC that fits without modifying the bumper?
Might be best to fit some slimline fans to get some more space?
Here's a shot of the complete inner wing:
In other news, I removed the Amal valve today - there's an in-car adjustable boost controller but I've also ordered a Dawes equivalent. I've no idea how much boost it'll make right now. I only have the standard boost gauge on the dash so I'll be watching it carefully. I think the next job may be to adjust the wastegate actuator to give around standard boost and then use the boost controller to go beyond that. Can anyone translate standard boost gauge positions to PSI?
By the way, I was pleasantly surprised to see that the tyre fitter used metal valves without even asking me!
Even the bumper isn't too badly damaged. It may yet live to fight another day (post/bollard, kerb). So I will definitely not chuck it. I also returned to the scene of the accident and retrieved all the broken bits of indicator lens. So, who, knows, I may even be able to resurrect that if there's an emergency need for one!
I was beaten in a race last night by one of these:
Looking at the specs, I can see why. Definitely time for that FMIC and those other subtle mods!
Car will be going in to the garage on the 22nd for the major mechanicals. Just building a list of things to do and collecting the parts!
So far, I think it will be:
- Timing belt and tensioner
- Head gasket (oil leak), with valve stem seal replacement
- Strut top bearing (maybe both sides, but driver's definitely needs doing). Associated rust repairs
- Brake hoses (and copper grease to hopefully solve VERY squeaky brakes)
- Offside front wishbone (want to replace while the strut is done), might do nearside too
- Might do poly bushes
- Prop shaft bearing - yes, I found one (in France)!
- Maybe the gearbox (and clutch at the same time) I might just chance the second hand 'box, without getting it checked, but I don't know if that's a false economy. The whine is worrying although you get used to it after a while
- Diff oil
Hmmm... I think my bank balance might be a little less healthy after all that lot! I'm thinking that the major engine/box work might be best tackled all in one hit.
Thoughts? I just want it sorted so I can enjoy it! It's not really supposed to be a project car for me - more like one that I can enjoy and tinker with when I have the time/inclination...
Andrew
