Have I got time to type all this out for the 21? Hmmm. Not today
Lets give it a go. Anything with a * is planned but not bought yet.
1990 Renault 21 Quadra
Extensive shell rebuild with new floor, sills and full roll cage built to my spec/size at home. Also a new roof skin with no sunroof hole.
Seam welded and powder coated subframe
New wishbones with strengthening plates, also powder coated
Complete rear axle, trailing arms and stub axles powder coated
All front suspension components powder coated
Stud & nut conversion
330mm front discs with 4-pot calipers & yellow stuff pads
15mm hubcentric spacers
310mm rear discs with 4-pot calipers, not chosen pads yet.
Rear bias adjuster
Spot caliper for handbrake*
Braided brake lines
Servo brake conversion to remove electronic accumulator system
Clio 197 brake master
Phase 1 hydraulic clutch setup conversion
Bespoke flywheel
Twin plate 185mm clutch*
Full standalone management, Adaptronic 420d at the moment but will upgrade to an M2000
DBW throttle conversion with retrofit cruise control*
36-1 triggerwheel on crank pulley
Custom engine loom
Racetech dash
12 Valve R21 TXi head transplanted on to the turbo block with...
>Bespoke Nimonic 80-A exhaust valves
>Bespoke double valve springs
>Fully flowed and ported head
>Billet catcams cam
>Catcams adjustable pulley
>Custom valve spring seats, retainers and stem seals from a volvo
>Hardened rocker arms with a 2:1 rocker ratio
>Flowed OE 12v inlet manifold initially but also a Pulsar GTiR ITB option with 8 injectors
>Direct port nitrous kit (might use it, might not!)
Forged bottom end with...
>Bespoke Arias pistons
>Bespoke liners with wire ringing
>Uprated oil pump relief spring
>New custom made oil squirter jet springs
>Nitrided crank
>R21 Diesel shock absorber support thing that attached to the crossmember
>Uprated engine mounts
Bespoke tubular equal length rams-head exhaust manifold with 50mm extranal wastegate take-off
Tial 50mm external wastegate
MAC valve boost controller run by the ECU
3" Turbo back exhaust
3" front mount intercooler
Uprated rad & fans
(Havent chosen turbo yet but probably a GTX3076 or similar)
18" Bola B12 wheels
Likely PS4S tyres in 215/35/18*
Modified rear arches to fit wheels/tyres*
Europa Cup front bumper
Prima Evo bonnet with genuine Integrale vents
Europa cup sideskirts
Europa Cup boot spoiler
Prima rear bumper splitter
Thats what I remember - might add more later
