What are the running costs like
Ultimately the V6 is a cheap to run compared with the majority of other performance cars, and definitely for something that is effectively a mini-exotic
Petrol consumption is reasonable for a 3.0 litre V6 performance car. For typical usage, most owners report consumption around 21-23MPG. On longer motorway journeys consumption can be near 30MPG. When driven hard, or on short stop-start town journeys, consumption typically falls to the 15-20MPG range.
Servicing costs are very reasonable too. The service intervals are relatively long at 12k miles or every 2 years. A typical minor service costs around £200 at a Renault dealer. More expensive service costs are incurred for major service items eg. the cambelt should be replaced every 72k miles or 5 years and given the difficulty of engine access, you should budget £800-£1000 for a cambelt service including the replacement of the water pump at the same time.
The exception to rule is parts costs. Because of the limited numbers involved, there is a very strong multiplier when it comes to V6 parts. Imagine the cost for a normal model, and multiply it by 5 and you might be close to the V6 cost! Body parts are particularly expensive which is one of the factors behind a number of V6s being financially (Cat D) written off for relatively minor panel damage. In some instances it is possible to source V6 parts via other suppliers.
