I finished the last few bits on the engine this last Monday and then phoned Emerald to arrange a rolling road session. They couldn't fit me in until the 7th October which was a bit of a wait but they said they would put me on the cancellations list.
About 10 minutes later they called back, there had been a cancellation for this Wednesday!
I then found out that I needed resistor type spark plugs to work properly with the ECU.
Much phoning around produced a set of Champion RS9YC resistor plugs which were a replacement for the (atmo Gordini spec) NGK BP6EFS I had in it.
The rolling road session wasn't straightforward. Dave at Emerald really struggled to make any sense of the readings from his rolling road due to the wierd Daf Variomatic gearbox in the car and in the end couldn't produce a proper power curve but did manage a few readings at set rpm.
90hp at the wheels at 4000rpm, 111 at 5000 and he thought he saw 130 at 6000 before it started misfiring, banging, popping and running really rough!!
I feared the worst and Dave looked worried but after some investigation it was down to a coil pack lead coming loose.
Dave had got the car mapped pretty well by then and was reluctant to keep beating it on the rollers with the "hot" atmo spark plugs in it, in case one broke up. He thinks Gordini turbo heat spec plugs, an 8 in NGK would be suitable albeit in a resistor type before I use it hard.
A quick spin up and down the road to try it showed how smooth and punchy the power delivery is now, it boosts from about 2300 rpm and the turbo whistle is amazing. You can just about hear it in the video over the rest of the row but it sounds much louder in the car.
I will do an in car video soon once the cars properly on the road.
