Time for a update on here.
Since i decide i'm not do the f4rt engine swap last winter, i had some ideas to make the twingo a bit more fun and give it some extra track performance.
Airducts:
A member of the dutch twingo group made some airducts to replace the foglights.
There are made to feed the airfilter of make brake cooling.
I've just put them on for a more sportive look.
Weight savings
I took out some ballance weights on the passanger side of the car, total saving 9.1kg.
Also bought a lightweight battery, lifePo4 lithium, only weights 1.1kg so i'm saving a massive 17kg on the drivers side of the car.
More power and noise
The little twingo could use some more exhaust sound in my opinion, installed a Ktec decat exhaust manifold. The sounds it makes are awesome, sort of rallycar sounds from back then when they ware NA powered.
After that the car got a remap to suit the decat and turn off the 2e lambda sensor so no fault codes came on. It made 143bhp and 178nm. Its not much faster but the powerband is more useable.
Soundclip:
Season opening nurburgring 2023
So the first day of tourilaps opend on march 19th, it would be rude not to go and do some laps.
It was a bit cold, and some light rain now and then, manage to do 10 laps and it was a lot of fun from the first 1 on.
Spa francoschamps
Booked a Javelin trackday at spa francoschamps, first time for me with the twingo.
Was a bit scared it would not be fast enough, obviously it wanst on the straights, but all those legandary corners made it worth 100%
The weather was awesome, the vibes on and of track where good.
I chared the car with
@YannikS as his car is stored at the nurburgring during TF season.
Season preparations
The car got a full service and check up over wintertime, change the engine and gearbox oil, 4 new yokohama a052 tires.
All was good, this thing just keeps going.
Thats it for now, not much going to happend during season 2023, just want to drive as much as possible.
Only thing i have doubt about is changing the coilovers to a AST 2 way coilover, well we see how the want for that will held up during the upcoming summer.
