yabx172
Hi,
Let me show my track build even if it's a non turbo build .... for the moment.
I build the car myself during year 2018 and 2019.
From scratch it was a 1.4 16V 95ch coupé, now the car made 180hp, 940kg. I use it only for trackdays.
- Engine : F4R 736 with "cup" remap
- Gearbox : JC5 090 with RSX torsen and short main gear ( 14X69)
- Eletronics : i stripped the oem electronic loom to keep only what i need !
- Interior : Completly stripped
- front axle : Cup intrax coilovers, laguna hub, 280mm brakes, pure motorsport anti-roll kit, welded subframe ...
- rear axle : Scenc rear axle, with more camber and bearings upgrade, 238mm rear brakes from Clio 172
- Brakes : 23,8 master cylinder, no abs, full braided lines, but disks and brakes are from the scrapyard
I've done about 20 trackdays with no issues at all, the car is really briiillant to drive ... but ... i need more power and this is why i'm here !
I would like to put a F4RT engine on it, i should get a F4R 764 from Laguna 2.0T 165. my project is to transform it into 225 and optimize it a little. The goal would be to have 250hp reliable and a constant torque of 350nm
