Will D93
I ordered a couple of suitable reducer 90’ pipes for the turbo oil drain. That sorted that leak but the oil temp at the front of the sump was a bastard to seal also. And now My crank seal has started weeping a bit
Jesus
Today i flushed the coolant system out and filled with type D. Sorted the weeping temp sensor like I said and had another play about with the idle settings trying to get it to run consistently.
I’ve got it pretty good I think.
I also had another go at sealing the pipe from my brake res, it’s leaking in the same place. I’ve used some epoxy glue this time in a hope that it’ll withstand the brake fluid.
ordered up some heat sleeve and loom tape to tidy up the engine bay slightly, and some sheet to make radiator cowling, CAD template lol
trying to find somewhere I like that will mot it at the moment. I have insured it, at £195 bucks for the year, which I am very happy about.
cheers
cheers
