5 GT Turbo Raider Update....
Hi guys,
Not had chance to do an update for a while, ill try and get a few pics uploaded while I wait for my chopper home today.
Got a few things to do this time home, my plans are:
1: Engine mounts, is it a ball ache and what's the best way to go about it.
2: Change carb top mines cracked.
3: Put the little plastic fuel filter in the barb and hope it sorts out my bogging issue.
4: Pressure test boost hoses
5: if everything's good with all the above hopefully turn up the boost more and hope its not going to surge like a b**ch.
Might look at getting some headwork done. Anyone got a company they would recommend.
As promised some photos of progress, theres loads of pics so apologies.
Due to the large air intake i moved the header tank to the bulk head but thin king of moving it again to the driver side. I think i have a duff tank as its leaking at one of the joins so if i can get hold of a good OE on ill prob move it then but for now its ok.
Went to B&Q for some pipe work to extend the top rad hose, had my little helper with me....
Originally id sent the car to have the FMIC fitted by a so called mate haha, he couldn't do it and ended up with a raider with no front cross member, so thanks to @Brigsy we did it ourself. Started off with some angle iron and flat bar from Wickes 20150804_100539.webp 20150806_140624.webp 20150807_172821.webp 20150809_121546.webp
All offered up and fitted, was pretty straight forward to be honest.
Alterations to my MINT OE front grille had to be made, i think @Brigsy took great pleasure in this haha.
Mocal Oil cooler fitted
Slight alterations made to the bottom of the bumper, I wanted to keep it looking as OE as possible so really happy with the outcome, only a tiny bit of the IC shows.
New oil feed with T piece fitted for Oil Pressure gauge.
20150811_123710.webp 20150813_160131.webp 20150813_160136.webp 20150813_160142.webp 20150813_162646.webp 20150813_162652.webp 20150813_162658.webp 20150813_170053.webp 20150813_170057.webp
My helpers at it again
All pipework plumbed in and ready to go.
More power now means the OE tyres i had were no good so a set of Toyo R888r were purchased, not had chance to find out how good these are as its been damp lately. a good test will be at Blyton.
Had the front bumper resprayed and also the house filled in to give it more of an OE look
New strut brace fitted, bargain at £20 and then £20 for powder coating.
New looking front end
Carbon fibre badge purchased, i had a Renault one but it was too big, then seen this and thought why not....
@Brigsy fitting the new Armtek rev limiter
Had to purchase a new .64 rear, i had a .49 but had really bad surge issues. so swapped it over. still have a little surge. I need to check the size of the compressor wheel and a pressure test and go from there. The surge isn't bad but not desired....
20151030_183212.webp 20151030_183219.webp 20151105_140706.webp 20151212_141437.webp 20151212_141637.webp 20151212_142146.webp 20151212_142158.webp 20151218_135951.webp
So a lot of pics etc.... overall the cars performing really well its running about 19psi and she shifts. As above I've got to do a few more things this time home then hopefully turn the boost right up.
So I'm all checked in waiting for the paraffin budgie to come get me and take me back to civilisation.
It gives me time to think of the jobs I need to do on my leave.
Well it's booked in for a full valet and clean tomorrow ready for the Northern Renault meet with PFC magazine coverage. Then I'm down rotherham for a few days on a course. Once I'm back the work will start.
In no particular order my tasks are:
Check the compressor size on my Gt2560r,
Re-hang my exhaust as it's not sitting right,
Possibly look to move expansion tank to driver side scuttle area,
Take the head off and send it to CTM for full head work,
Sort my passenger seat rail as it's not moving,
Sort my electric windows out as they are so slow,
Fit new speakers in the front and back.
Also need to build a work bench I the garage.
Hopefully I'll get it all done but I have 2 courses to attend this time home so my 3 weeks leave will be down to 2 weeks.
Updates to follow......
