Ive not had it off so I dont know. Its something someone mentioned to me, its not from direct experience, I just know that its a possibility due to thesilicone around the bottom.
After a little help with the circuitry for the interior fan. Just received a new fan from ebay. Fan works fine connected to the battery, but not when installed. No fuses are blown. I measured approx 12v at the terminals for the fan. When i toggled the fan speed controls the voltage dropped. What is going on????
@DaveL485 Looking through other threads, you might know whats going on?
I think its inside the heater box, which is a PITA! Atleast, i can see a coil from above where the fan sits, but i dont think you can access it without removing!
Got some new air hoses from ebay to replace the very tatty looking ones, I think these look decent enough. The fuse has arrived to fix the blower, so that will be to do in the next few days!
Ive no idea, open to suggestions!! I also dont know what the thing above it is with the wiring harness, because one of those sets of wires doesnt go anywhere
Find many great new & used options and get the best deals for Renault 4 Vacuum Reservoir 7700740002 (fits Other Models See Description) at the best online prices at eBay! Free delivery for many products!
Thats another job done .... dash out, heater box out, dismantled with new fuse ready to fit, only to find there was no fuse!
Looks like mine is the type without a fuse, so, i wondered for a little, then decided that the huge amound of rust on the terminals wouldnt help. Got out the multimeter and confirmed conductivity issues, so cleaned up the terminals with a dremel. Applied to WD40 and put it all back together. Put in enough dash to test and.......it worked!
So, if you have a non working internal blower, and everything looks fine, it could be the terminals on the rheostat.
Tine for a bit of soldering, tidying up the mess that is the radio harness. A mixture of bare wire and bullet connectors. Best replace with a nice ISO harness with soldered, heat shrunk connections
So, my rear wiper doesnt work correctly. When I press the button in moves about a third of its cycle and stops, then moves a bit more, and finally the last third.
Would that be a faulty wiper relay, the Klaxon 54616, or something else?
