Updates
Parts all arrived from Kamracing, great service. So started to crack on with the work.
First job was to clean up the track control arms and pop the bushes and balljoints out. 20ton press and knotted wheel on the grinder made short work of this.
New vibratechnics rear solid bushes pressed in, powerflex black up front and new trw balljoints. The rear vibratechnics are a rose joint with rubber boot, look pukka. The main advantage over powerflex rear bushes is they can pivot properly like the oem rear bush allowing proper droop on the front suspension. Best be good as they cost double the price of powerflex.
Coated in hydrate 80
Zinc primer, epoxy mastic and a gloss top coat.
Next job was to upgrade the front arb. Stock Kangoo is 19mm and r26 is 21mm so a decent upgrade. The bars look identical so relatively straightforward swap.
The easy way to do this would have been to use the r26 subframe which bolts straight onto the kangoo. The downside to the megane subframe is that it runs crap bushes in the subframe, and the Kangoo is solid mounted like a clio 197 cup racer subframe, so was worth sticking with it.
Kangoo subframe mounts
Stock arb brackets were no good as for smaller bar and very flimsy, and r26 would not fit as different.
Had a sniff round the renault parts bin and found the megane 3 bushes were for a 21mm bar and looked similar to kangoo. Slight elongate of the holes and straight on.
Next job was to change drivers side outer cv as clicking. Easy job just messy.
So next job was to pull the box out to replace dmf for new oem and fit the new rts clutch. Its the dual friction type which is tested and good for decent torque.
Pk gearbox a bit of a lump to remove but not too bad. Clutch did not look all that bad but noted that self adjusting mechanism on pressure plate was not set even though it was fine when fitted!? Dmf was shot play in all directions. I knew this was not the best as had a bit of vibration off it.
Crank seal i fitted with the proper tool still nice and dry. Actually cant believe its leak free.
Dmf/Clutch fitted, note self adjusting mechanism set properly.
Box back on, new oem renault slave cylinder fitted. Bled up straight away and a good clutch pedal. Just bolting it back together at the moment should be finished tomorrow, need it running for Friday to pick up a petrol patio cleaner:LOL:
Thanks for reading!!
