Mapping day yesterday. Had prepared as best as i could and packed a few spares "just incase". Steady drive down to Efi made it there in good time.
Pre checks done, fuelled up and parked waiting to get on the rollers. Moggy arrives for a catch up in his epic nimbus r26r.
Waited for Chris to finish up with another car on the dyno.
Firstly engine ecu was removed to bench read and write a new base map as the ecu was locked from previous map. I fit 250 map sensors and hook up the vac pipe for the rising rate fuel reg on the 250 rail.
Chris fires it up to check the base map, connects the hardware to map via obd. We run into problems at this point as the software does not recognise the Kangoo 2 vin number that is stored on the engine ecu and wont show any ecu data, boost pressure, charge temp, knock count etc.
This was a problem as cant tune it without any data logging. Long and short of it is, when i done the immobiliser sync i changed the engine ecu vin number to the Kangoo one to try and view it on clip (which did not work). The only option was to reload the megane R26 vin number so the software would recognise it, which was a bit of a carry on as the ecu needed to be a virgin immob file and would not write the vin without a bench flash back to virgin.
Luckily i had my laptop with me so found the virgin immob file, bench flashed the chip and resynced the immobiliser with Ren0link. Ecu vin changed and the hardware recognised the vin allowing logging to be done.
Onto the dyno.
Chris asked me what i expected from the setup and what my use will be, i told him i want to drive this hard and track use so can sacrifice a bit of power for safety. He mentioned the 172 cams on stock timing may make the setup a little bit more laggy compared to usual megane, but that could work really well and make more power with less boost than stock 250 cams, and keep the drama out low down in the rpm which is good.
Part throttle mapping first.
Chris starts dialling it in and the power comes up fast and its looking like its working quite well. Safe 300 hp, 350 hp on 2nd run. Intake/Charge temps are really good and the rising rate fuel system is working well.
Wound it up a bit more and see 382hp @23psi
Clutch started to slip a little on spool at this point so had to pull boost up to 4000ish rpm and limit torque.
End result 375hp & 337ft/lb. Made up as i was expecting around 340hp and anything over that was a bonus.
Video of the final run.
Took it for a road test and it feels ballistic for what it is, its hilarious just squats and goes.
Traction is a major issue in first 2 gears and its quite hard to keep straight so chassis needs a bit of work to dial it in and it definitely needs some sticky rubber for track use, and a clutch upgrade very soon.
Massive thanks to Chris @ Efi for epic service as usual, he totally went above and beyond and stayed back late to get it all dialled in and finished after the initial issues with the ecu. Overall it drives fantastic and very pleased with the results.
Thanks for reading!!
