Brigsy
Media Mogul. Instagram legend.
CSF update.
Csf done and pretty successfull overall, the stars finally aligned. 600 miles on the trip, 3x tanks of fuel and 4x track sessions on the pm.
Sat ready to go with the Extra.
I was anticipating a 2 lap wonder and something to go wrong so had datalogger in initially for first few laps. Checked logs, coolant temps were very good 87deg, Iat great 5deg above ambient, no timing pull or noticeable overboost issues.
I thought id broke it with vibration on certain parts of the circuit but was due to the epic amounts of rubber on the circuit.
Full send after i got used to driving it. Its quite hard to pedal, suspension needs dialling in better and you have to feed the power in on corner exit as its pretty lairy. Can rotate the back end nice with trail braking on the tighter corners. Its planted at speed on the throttle and when cornering but its a bit twitchy on high speed braking 100mph + but controllable.
Finally works. Pizza on the evening to celebrate success.
Spotted on the way back on a55 iirc?
Back at van HQ safe and sound.
24mpg overall, not too bad. It was drinking it on track so assume it levelled out on steady return journey.
Give it a once over and all seems to be good. Have refitted the white mo's with the cup2s as more road friendly.
Thanks for reading!!
