Are the Headlamp washer jets on the phase 2 the same as regular Clios/Lagunas etc? I need a near side one and before I get stung at the stealers...maybe I could get a bargain on FleaBay
Matt,
they are easily accessible from inside the front wheel arch, its a case of removing the wheel and unfastening the arch liner although you don't need to remove it, can be a bit fiddly i seem to remember the Near side being easier to fit than off side.
Matt,
Don't worry about having skinny fingers, you won't have skin on them when you are done i think a 22/24mm socket fits over the nut once the pipe is removed, will check got my old ones in the garage
