r5gordini
Can you mount the coils on the engine? Make a metal plate (for example) like...
Wow! Good idea but I think I'm constrained by space. The turbo goes right where you put the coils. But it is food for thought. I need to refit the turbo and play around with various locations. I must admit it would be better to mount them near the plugs.
But is it? The point i would have made would be 1)the immense time investment has a 'cost' and 2)with the base ECU's often you will spend as much getting it to work as a package ECU.
Very good point. I am going to have to build a lot of bits, like the IAC driver and the turbo solenoid driver, etc.... The time investment is enormous, especially if it doesn't work! But I console myself that the ECU is only the last bit of the wiring puzzle. If Megasquirt doesn't work for me I can always replace it with Adaptronic or similar. You just want me to be done so I'll build you a fuel computer!
It's on my list...
