This interests me, as ever since I swopped 750 box to a 318 four speed the clutch has never been as good, the 318 uses a fork arrangement, whilst the 314 was a cranked pivot.
Unless I have virtually no free play on the cable it's a bitch to get in gear, anything other than bang into the carpet and it snatches.
My point is I don't think the fork set up moves with as little effort as the crank, wonder your increase in pressure plate effort is causing flex anywhere ( I had to beef up the pedal end of the cable mount as I could see it flex on the floorpan when an assistant sat in the car and operated the clutch) I was wondering if a Dauphine Gordini, which my whole rear set up is had a greater pedal pivot, and whether lengthening the pedal end would give me greater travel?
This is a bit of a thread hijack, but my point is I changed box set up and had issues, you changed pressure plate and had same?
I've had previous issues where I had burrs on splines on friction plate and this has caused your issue, so always check they're nice and smooth on shaft.
