Basically Yes it is all do-able.
Choices are
1.Use a GT turbo motor and make your own exhaust manifold There is enough room........... Then you can follow the tried and tested routes to Destruction.............
2. (i) Drop the compression on your atmo and (ii) make your own exhaust manifold to take a turbo use a 5Gordini/alpine/ Alp/Gordini turbo inlet manifold modified to take a throttle body and injectors.........
3. Build up another motor and follow step (ii) above........... Plough your own furrow to destruction......................
All have their pro's and con's
The R8/10 Bellhousing needs opened up a couple of MM to take the gt turbo flywheel as it is a smidge bigger
You can use a R5 Gordini turbo flywheel to save this issue, but the Renix trigger may not be good for modern aftermarket ECU.
@paule78 and I are working on a Flywheel for his phase 2 mods. TTV in the UK will make whatever you want, I'm trying to get it so that it all works and improves the clutch.
I am no expert on turbos or ECU's being firmly stuck in the past, But can answer any specific questions about what fits and what doesn't if you have them.
Flywheel, clutch and starter All pose issues, but I think I have a fix for all combinations. Paul's 8 had the original bellhousing modified to take the GTT starter, but the Clutch mech is struggling with an uprated 200 mm clutch, so we are going back to a 180mm with the centres moved about on the 200 flywheel
If starting from scratch I would use the Standard smaller flywheel from a MK1 5A or G with a trigger to suit or on the crank pulley, then you have covered the installation issues without having to chop anything up..
Modern turbo technology does not need such low compressions as was in the past. Problem with that head is that having the ramp machined out of it will make it more likely to detonate (the ramp was a lean burn anti-det idea ) it does not need the ramp if you want to rev it to 9000 rpm, but is much better with than without. It is all to do with squish and promoting turbulence in the chamber at lower rpm which allows weaker mixtures without Det. Like Amedee's masked spark plug idea which started the flame front in 2 different directions (like a twin plug)
One thing about all that mid range torque is that even with a big box it feels short geared and it could pull another gear, but No. I'm not making a 6 speed............................
la préparation de piéces de compétition / leurs avantages et leurs fonstions/ vue et réalisé par Jean-Marc ALBERT
This guy is the most Hardcore nutcase I have seen. He does not talk about money, I guess because if you have to ask you can't afford it .. Set aside a Half day to check it out...
