I ran mine on the STD map he supplied at 10psi with out issue. The car has I believe done several track days at that with no issue not even custom mapped.for now yeah, custom mapped. I think it will do a max of 12psi?
Another tiny piece in the form of an oil thread adaptor. As we know i do things as cheap as possible, the oil feed line was a freebie from work but its end didnt fit the turbo. Initially i tried back at work for a way to join them together but came up short. Quick trip to Pirtek saw me with the correct fitting focstill need to sort the block end of things though.
View attachment 120324View attachment 120325
Cheers @Mark Davis for sorting me another bit, just one more adapter to find amd the oil feed side of things should be sorted
Mine is still as it was when yanked out of the car. I will give it a bit of a clean up once all the mocking up is completeThese blocks rust for a laugh don’t they...!?
wooo if you did that would be awesomeI may have the adaptor for that last bit too, will check tomorrow.
