Lighter nights I've started having an hour or so, calmed down on weekend now weldathon is over,
Bottom to top............ old..........ATe reman.........Waf Eaton Engineering quality, preloved, rattle can rebuild.....
Bay cleaned, only bits painted are chassis legs and inner wing panels that were plated, rest original paint with a bit of poundshop polish on, servo cleaned up and a new master on.
Sub on with suspenders, rack and one brake pipe re-flared, short one new, gravity bled for now
Short springs on temp........tie wrapped some pipe insulation to pack them out so I could fit them....wary of them slopping about before I drop car and trapping new top bearings in an awkward position and damaging them.......obviously it won't get driven on these at all
It's only going on temp, then I can drop it of stands and roll it under lump, drop that in then jack it back up and put shafts in.....it's all messing about up and down but easiest way of doing it at home........car has to be out of way of bike, tight on room etc etc
It's always the things you didn't expect that throw your planning out, despite box being wet with gunge, stay bar to engine bolt snapped when I split box off motor....seized in big time
Tried this........
Failed, so luckily as it wasn't in a blind hole, I just centre punched it and drill it out in increments until there was only a thin bit left, small chisel cut down, and then folded it in on itself, quick run down with a tap, sorted.
Degreased box and tried cheap tack clutch, I'd hoped it would be a re packaged LUK............but looks like it's more likely melted down rikshaws.......Be reet...
Tart motor up a bit, but I'm not burning hours away at it, I've washed it down with white spirit, and got a production line rust bathing brackets.....bit of satin, just so it looks presentable, but I'm pleased it's coming together now.
