Good effort, thats an M10 no? Must have had some pull behind that to break it!but i managed to sheer the bolt that goes through the dogbone mount into the bell housing last night :@...
I was wondering where you had got to !
love 2118's and ive just fitted the scenic shifter to my clio, been a while, hello again.
yeah i popped it up on there. it feels awesome, stick is at the right height now, was always a bit of a stretch for me. The chap that does them says they are stiff shift and short shift but i dont buy it and cant see any modifications to the ball to stiffen it up. They are modded scenic ones so are shorter than they would be but i cant see or feel it being any stiffer personally. I also measured the throw on my original and afterwards and its within 5-10mm of the original throw, just alot higher upyou can also adjust the position of the stick using the linkage, i will be moving mine about 10mm further back but that's due to mine being in the wrong position to start with and some numptys have slightly collapsed the gear linkage meaning it needs to come off to fix.
6'6" here with a 36" inside leg. I have to fold myself up to drive a damn Clio LOLYeah I've got to stretch a little due to being long legged so if helps great plus fraction of the cost of the pms one
not sure if i missed it, but what ecu are you running in this?
It seems to be a pretty solid recipe doesn't itI'm using adaptronic 420d that was supplied and fitting by Efi parts
@W33 BRL any updates ?
