Class…
Learnt a lot there! Thanks @Wheelers WorkshopHi All,
Points well in my experience they are reliable, especially the Ducellier points in the R8/R5 distributor, I have been using them for over 50 years in my various Renaults without any issues, saying that I did have a set close up after driving the R8G to France for a weekends hillclimbing, but they are easy to check in the field and adjust as necessary. The Dizzy I am currently using is the R5G Ducellier externally adjustable type so the dwell angle can be adjusted with the engine running by turning the external adjuster nut with a 7mm small spanner and utilising a dwell meter [ which I now carry in the car].
Its tempting to upgrade to the numerous options of Electronic variations , but the Ducellier spring is good for avoiding points bounce at high RPM, British Cars would usually need upgraded points [Cooper S type] with an uprated spring to get them to rev clearly at high RPM.
The coil I use is just a normal 12v unballasted Gold Lucas item not complicated.
Most of my competing colleagues have encountered some kind of failure with electronic add on kits, which is no good when you need an operating correctly working engine say in Foreign parts to be also driven back to Blighty.
However I do carry a set of points , a condenser, Rotor arm and Cap , and a spare coil in my usual spares package just in case.
Finally, if you decide to soldier on with std French Points Ignition, don't buy anything other than genuine Ducellier quality components, when it comes to servicing.
Cheers
W
Really coming on this mate! Can see me getting the Raider or 11T taxed for the month of the Retro show to come & have a look!!![]()
Hi Guys,Top of the heater under the bonnet catch panel passenger side, go easy it may be brittle.
Tracking is disconect track rods and turn bush in Rack end 1 or 1.5mm per rev (can't remember) make a track rod conversion kit top of your shopping list......
