Which battery tray option
    Votes: 0 0.0%
    Votes: 1 100.0%
    Votes: 0 0.0%
  • Total voters
    1
  • Poll closed .
Squeezed in a short session as no garage update coming tomorrow booooo
Some hydro80 over all recent spot welds/,welds etc, dressed a few bits, more hydro80, welded patch in chassis rail...but not before getting some more you guessed it hydro80 inside 😀
Usual pre treat inside of patch and stuck it on flap wheeled it and some more hydro80
Did someone say Hydro80??? 🤔😆
Well with no free time the past week was getting garage withdrawal symptoms bad...
So managed to get a proper session in today to try and make up some lost time 👍
Fair to say many hrs eaten on jacking point but it mirrors the other one, fits well and will not move once welded in 😉
Did run out of hydro80 only to remember after a new 1ltr bottle had turned up doh lol. With things drying slower now temps have reduced removed the rest of the brake and fuel pipes etc...time for a beer and hopefully get section finished tomorrow 👍
Cheap tack halogen heater from poundstretcher as good as owt for paint drying, I've had about three over the years, they don't like overspray on the bulbs , so keep them out of the way , but get a panel nice and warm.
Good to have on near you as well, warm you up without the heat disappearing to the roof.
Saturday update
Got on with finishing the butt welding, and happy enough with the result, its flat and sill bottom matches long spirit level so will take that! Had some real fun at the front section and weld was not taking well at all had me a bit stumped for 10mins...transpires the magnet sitting above minding its own business was the cause!!
So carried on, few pin holes and a little bit of dressing and moved onto spot welding and decided a few plug welds spaced out as hard to know if spots are all 100%
Bit of tidying up still and finish front section and can formally tick it off 😎
Many thanks @Turbell 👌 - definetly a confidence boost for the surround of happiness of which there are a few approaches to decide on tackling that rot, having the spare one I crudely cut out of donor 5 historically at least gives multiple options.
I want to make a static adjustable jig on wheels to make the chassis 100% level and get it off the rottiserie which will help take weight off load points, addressing the next stages of built and transportation for paint etc🤘
Well finished off front and rear bits including, small patch I forgot about and bit of a tidy up after getting car level again.
Need a proper tidy if garage as 30mins was a mere dent after weekds of cutting, welding, grindimg, sanding joy is a proper mess
Fitted door and does not foul which was a nice relief 😎 although middle point of sill a touch up and will revisit another day
Feels like a bit of a milestone reached and almost car like lol
Nothing particularly exciting but got 2 patches in the floor in and look to finish tomorrow.....strange how a smaller job can be more of a pita but be all good once touched up and dressed.
Decided going to stitch weld the full shell although strangly on fence over a small detail to weld or seal the original access holes from mounting holes on production line 🤔
I left the ones on the inner sill open on Camprust, let it breathe, jacking outrigger ones give good access to cavity wax.
As far as seam welding shell....dunno? Is it gonna make a deal of difference on a road car?
Is it better to have a bit of flex on shell as whole, rather than possibly concentrating all the various forces onto an unknown weak link and cause cracking?......only musings, not my area of expertise , probably doesn't really matter either way, I'd say you've added a fair bit of lateral strength in the sill area with long butt welds.....take a plate of unwelded sheet and compare it to two pieces butt welded together, I know which one is stiffer, even ground back.
