Been getting the time in on this. Mainly buying parts I didn't think I'd need to.
Meriva A knuckles found. Wheel bearings bought. And I had previously bought the big block 4 stud hubs.
Pulled the old bearings out and fitted the new ones in with the bearing press tool I have.
Got the hubs in.
Brakes back on.
Brake mounting. Suspension mounting
Lower ball joint and tie bar mounts all in the same positions. I had to do this to fit the larger driveshafts. The other option was to cut and shut the original shafts with the new ones.
New correct sized abs rings ordered and awaiting fitting to the shafts.
CV grease ordered.
Once that arrives I can fit the shafts and see if they fit (nervous about that). The I just need the gbox fluid and I can test the drivetrain.
I've had a right faff with the rear engine mount. Getting the parts I needed. Then having to realise I still needed more parts. So that's all on order.
Once that's in and done it can go on the floor.
I then need to sort out this throttle cable mount and to modify the fuel pump housing to fit my Mégane pump.
Then... First shakedown.
Then fix all the mistakes and finish the wiring.
It still has no coolant temp, revs, or Speedo.
They all have their own ways to be done but it'll drive without and I can use the obd for those for now.
Then it needs some lowering springs and I'd like my Renault wheels back so it needs some tyres. And I need to arrange getting those brembos on. But money really has run out for now. So these will have to wait.
Cheers
Also the Clio is in daily use and still blows me away. It desperately needs new coilovers or some lowering springs, and a map adjustment. But it is going to take some beating....
