I can see it now. 'no it needs semi slicks....for safety 'Hould just let her know that you need to lower it, bigger brakes, and different wheels, all for safety reason since a 270bhp engine is going in ha ha
So with a few last bits coming for the Clio (which is running well) I've started taking bits off this engine.
Exhaust manifold is offView attachment 207446
1 snapped bolt was left pushed in for me. So I'll have to try to get that out and replaced . Exhaust gasket ordered.
Inlet manifold is off. No snapped studs but when cleaning up the threads, one of them gave me a bit of grief. But I believe it's tight enough now.
There was an attempt to clean it. But it's not really worked with degreaser. Might just sand blast the aluminium bits.
Injector rail is also off. And will be put aside for cleaning.
Unused idler taken off (I believe it's obsolete as there's no air con anymore)
And I'd like to get the belt off next and have a look behind the timing chain cover. But I think I'll get it in the air for now and attempt to get the gbox off.
I have ordered that oil pressure sensor for the back but I'm struggling to find the cap on the cam. I think I'll knock it out and reuse it with some gasket seal.
Cheers
That was quick getting the cam bung! I'm guessing the oil sensor was leaking/wrapping?Got my bung along with inlet and exhaust gaskets. (Inlet was the wrong side of the sandwich plate which is now removed but I'll reuse the original anyway)
Waiting for my oil sensor.
Also had the gearbox off for a slight clean and and to see how much life the clutch had left (lots) then put it back on.
Ordered the selector cables.
Went to test fit.
Something is missing FFS.
I can't find part numbers or any for sale. So I asked on saabworx and got one coming to me straight away.
Also had a look down the thermostat housing and saw something I didn't like.
Which turned out to be fine. But the thermostat gasket was ropey as and needed a new one anyway. So stat and gasket ordered.
Getting there
Cheers.
It looks like a bailey or similar one. It's gonna go anyway.i Believe the DV on these engines are a piece of shit, just get shot as said. Good progress, shame about project slowing right down tho.
