Itās been 8/9 months since Iāve looked at the campus, at the end of last summer, having put a lot of effort in the first lock down to actually get it built and then working through teething issues as much as i could it came time to stop looking at it for a while as it was frustrating me.
so itās been in the garage at the house since last September, and I moved into a separate unit in October. The car has barely seen the light of day.
issues I knew I had, wanted to revise were
wheel/tyre fitment, mainly rear axle width needed to change
waste gate actuator, fitted is the standard one to suit the turbo thatās been fitted, stock figure according to the internet is 6-7 psi
- I wanted to fit something aftermarket with various different spring rates to get rid of the wank bleed valve set up
I was never happy with how it was running, it would start and run. But not well, and would cut out at a junction. Not ideal
I needed to remake the turbo support bracket I made as when I changed gearboxes the mount holes I came off of were not there anymore. Conscious of the weight of the turbo I wanted this done
So, I decided about the end of March it was time I looked at it again, get it out this summer for some miles, maybe take it drag racing at crail or a track day to knockhill if possible.
So first and a fairly big thing was the rear axle width, I found a campus axle in Inverness, got it moved down to my work via the company parts vans (Tidy!)
I got the car moved to my new unit on Friday, immediatley set about swapping the 16v axle for the campus one to test the fitment/spacing
campus axle fitted, lowered to suit. Williams wheels fitted, and Iāve got space to run decent tyres, happy days
I need to get flexis for the back axle before I can get the lines remade etc so that put that bit on hold for just now,
I set about making a new turbo support as I could do that with what I had in stock, I decided to use a rose jointed rod I made up for this purpose originally.
happy I got that sorted out, only other thing I could do at this point without more parts was look at the running issues.
I got it running smooth last night at about 12.5 AFR, which considering thereās a cam in it is probably alright. Stop and start it no problem, running fine when hot. However the idle screw was backed right out, must have been about 8 turns at a guess.
I left it over night and it was a pig to get it going today, misfiring when it did eventually start, cleared up but wouldnāt idle without throttle.
I decided to remove and strip the carb to clean it, I had cleaned it previously with the ultrasonic at work, and blowen it out etc. But it then sat in a box for a month or so before I rebuilt it, and itās now been sat for 9 months.
so itās stripped down and steeping in V-Power at the moment, Iāll get it blowen out and rebuilt this week. Refitted and see if thatās made any difference
also on route are a new set of r888ās, a mamba wastegate actuator, rear brake flexis so i can get the axle plumbed in, a couple of torques bits to revise the turbo oil feed.
more updates to follow, thanks
