So it mothers day and we are lockdown so the best thing to do is obviously head out and work on the car right? i did take one of the the kids out with me so wifey wasn't left to do all the work.
Started with a compression test, the results were very low and off for a car that runs ok in my opinion.
Cylinder 1 80psi
2 65psi
3 67psi
4 100psi
I think i need to do a hot test and check that again and also make sure im using the compression tester properly. I gave the head a re-torque on the off chance it was loose with age, 2 of the hard to reach bolts have slots cut in them so im assuming someones done a HG previously but couldn't get a socket in? I could though so loosened and nipped all of them up, they all took a bit more torque than i needed to release them. I then reset the valve clearances again to make sure they were correct. I can't run the engine enough to warm it up but after the last few jobs being done it literally started instantly. Better than it ever has before....... can it fire up so well and still have a hg gone....?
Cylinder 1 80psi
2 65psi
3 67psi
4 100psi
