Starter Motor - Replacement Guide - WITH PICS
Nice shiny new starter arrived today, only ordered it yesterday.... great service so I am raring to go :)
All done, not too bad a job really :) never heard a car crank as fast as my vee now!
Old starter dismantled, dislodged and broken magnets was the cause, just like jims...
Damn......... You've beaten me in getting the new starter in. Mine should have arrived today (Asked them to deliver it today, as I was working Wednesday), but I'm still at work (Night Shift). Hopefully my neighbor has accepted the delivery and it'll be in by mid day tomorrow.
Hope the removal and replacement went as smooth as mine, and you had no problems. It's an easy but fiddly job, but anyone with a bit of mechanical knowledge could do it.
As for the fault being the same as mine............. Seems we have identified a common problem. The good news is that the company who we both got our starter motors from sells them at the cheapest price I've seen advertised, but more importantly is aware of this problem and uses a different process to secure the magnets to the casing. So hopefully, a better starter motor than buying a brand new original unit which may well have the same inherant problem. And at a 1/3rd of the price ...................... and no exchange required ! ! !
I just noticed the MK 1 starter motor Renault trade price costs only £75 and retail £150. A different Valeo part number. I've not read of any MK 1 owners having starter motor problems, so perhaps this unit is much better? Very old MK 1s are still cranking over.
Would it fit a MK 2 I wonder or even swap its internals into a MK 2 casing?
Just thoughts from my non technical head.
Ok..... New starter motor in, car up and running and all back together (Didn't even end up with a spare bolt or washer......LOL).
Like Martins........ The engine is spinning up much faster on the new starter.
Now I just need to have yet another bath.
For anyone needing to repace their starter, its not a hard job and from start to finish is about four hours work if your using hand tools. No real problems if you follow the sequence above. If you have access to a four poster, then It's probably less than 3hrs work, as I spent a good half hour messing around raising and lowering the car.
UPDATE : Having completed the job, I now realize that there is no reason that the oil needs to be drained from the sump.
Good Luck.
Jim Green":259ri3jj said:
UPDATE : Starter Motor Out.
Ok, as it looks like I'll be replacing my starter motor that appears to have given up the ghost at 16k miles, I thought I'd give a step by step instruction as to how to replace the starter motor as it appears it might be a regular occurrence for us V6 owners.
I have a garage which is a little wider than normal (I can open both doors fully at the same time without hitting the garage walls - Just to give you an idea of the space I had to work in). With good strip lighting, and a good set of hand tools and inspection lamps to see what I'm doing underneath the car. I'm not a mechanic, but have done alot of work on cars (Mainly Cosworths & TVR's)......... So I'm not affraid of getting my hands dirty. I work methodically and logically and try to familiarise myself with what's involved in the job before I start. So....... Here Goes.
1. To start off with I used a 3 ton hydraulic jack, and 2 x 3 ton axle stands, first raising the car at the rear by placing the standard fitment Clio car jack in the correct raising points, just forward of the rear wheels..... One Side at a time, this allowed me to get the car just high enough to get to the rear section of the undertray and remove all the bolts (10 x 10m bolts in total - The one you'll miss is the one dead center in the middle in the recesses securing point), Once the under tray was removed, I could now place the hydraulic 3 ton jack under the center of the rear section of the rear subframe. In order not to stress the center area, I used a block of 4 x 4 wood, 2ft 6in in length and placed this between the jack lifting point and the rear cross member of the subframe...... this ensure the weight of the car was supported across the full width of the subframe so nothing was stressed. I lifted the rear of the car so that the rear wheels are about 9 inches off the ground, and then put the axle stands in place, one each side of the car on a strong area of the subframe.
Once the rear of the car was safe in the air, I removed the battery connections.
Then it was time to drain the oil........ If your going to re-use the oil (Which I am, as it's only done about 1k miles) let it drain into a clean container, and then pour it into an oil can/plastic 5 ltr oil drum. This will ensure it doesn't get contaminated with dust while your working.
Then remove the oil filter, and throw it...... You'll probaly damage it to a certain extent when you remove it, and for the cost of a new one its not worth keeping.
Then remove the Modine Oil Cooler, this is the part which the oil filter screws onto....... you'll need a 27mm ring spaner/socket to do this, by unscrewing the protruding fixing that the oil filter screws onto. Once removed, then remove the two metal coolant pipe securing bolts (2 x 10mm) from the rear of the subframe, this allows you to move the modine cooler and pipework out of the way to give access to the starter motor area. Place the modine cooler in a plastic bag, otherwise it will attract dust and and any grit in the air or from your garage floor. Once this is done, move the whole assembly clear of your work area (There is no need to remove any of the coolant pipes, leave them all connected). Keep plenty of rags handy as you will get oil dripping from the block once filter and cooler are removed), I always keep a tin of gunk handy to clean any oil spills from the floor, quite simply because it drips exactly where you'll be laid to complete the rest of the job.
Now you can see the starter motor......
Now it's time to remove the heat shields from around the pre cat, you will see where this is as there's 2 x CO Sensors bolted into it. Remove all of the 10mm securing bolts and the two sections of the shield will now be loose, but you only need to remove the one shown in the end picture (Your prevented from removing the second shield as one of the CO Sensors goes through it, preventing you from removing it. Once these two sheilds are loose, you can move them around enough to remove the starter motor shield (2 x 10mm bolts) ...... Once this is removed, you now have access (Only just enough) to remove the three starter motor securing bolts....... At first you will think that you are prevented from getting the last of the three securing bolts out, as it is blocked from coming out by the pre cat and remaining heat shield (Which is now loose and can be jiggled around, but not removed due to the CO sensor going through it - But this isn't a problem, it doesn't have to be removed), with the two starter motor top bolts removed completely, you can then jiggle the starter motor around enough in order to remove the final bolt, the starter motor will drop down enough for you to get access to remove the power cables....... this is made easier (Allowing the starter motor to drop well below any obstructions, if you remove the power cable securing clamp by undoing the bold holding the cable to the block). Once you've done that, you can easily remove the cable from the stater motor without any skinned knuckles.
This is all of the parts, and all of the bolts you should have once the starter motor is removed. You do not need to remove any other parts other than these & the rear undertray......... Amazing how new it looks....... Now I'm going to try and get it tested somewhere to see where the faul lies, rather than just buying a new one straight away. Hopefully they may be able to identify what the fault is, and highlight the weak point that alot of us seem to be experiencing....... I'll keep you updated.
And here is the culprit........... for the two hours work it took me to get it out.
This dosn't seem to be in the knowledge base ???
I'm assuming the reason why ph1 and 2's use different starters is because the later car uses the crappy dualmass flywheel setup.
Great guide, don't take this the wrong way, but I would never consider putting used engine oil back in an engine whatever mileage the oil had done. Surely this is not recommended practice?
Mine has just gone as well, GSF has quoted me £140 asd £30 surcharge and is made by Delco? Anyone know this brand?
Blakey, give 'pturner3' a pm off here, he recently went through all this with starter motors.
There's not really a problem if its newish and well filtered. I wouldn't go by milage. If an engine stands over winter, its always best to change it as you can get condensation.
will do, thanks dan
Well got the starter out, followed Jim's guide (very handy [smilie=thanks.gif] ). I had a right struggle with the heat shield nuts. The 4 bolts themselves came out fine but the 1x10mm nut top side of the down pipe was a bastard.
Getting a starter from Plymouth today.
i found i was extra diligent when reinstalling the oil cooler block as you really don't want any contamination from dust, dirt or grit as you fiddle to put it back in place and bolt it back up ...
thunderstarter":2syiygr8 said:
Good Skills! how long did it take?
About an hour before that last nut, and then around an hour and a bit getting that off.
Took the starter to bits and it had the same damage as Jim's, starters may well be the new coils.
Martin, your right about the cooler, I have not got mine back together yet because of family round in a bit but will take care of that. One thing, the oil seal on the cooler, might get one? Did others fit a new one?
i removed my starter lastnight, therewas a few points i might add if thats ok.
there are four m10 bolts and one nut. the nut was rusted and snapped off this was found sat just on top of the bend in the exhaust, very difficult to remove once rounded off. i had to bang on an imperial socket and snap it off.
when it comes to the removal of the starter there is a clamp just above the top bolt securing some tubing this houses the cables, you can release this with a small 10mm long reach socket and extension bar i found it easier to add a reducer to this and use a quarter inch rachet.
once loose detach rachet and unscrew with exstension bar by hand.
this will help lower the starter down low to detach cables.
hope this helps a bit more.
just to point out i purchased my starter motor from a scrapyard off an 2005 renault laguna 3.0 same part number the laguna had low mialage and only cost me £25.
