Starter Motor - Replacement Guide - WITH PICS
If you manage to fix it successfully, you will be duly obliged to change your username from:
Peternofx
to
Petercanfx
Mission accomplished, Petercanfix indeed ;)
Thank you very much for the instruction.
The V6 is starting like a Lion :approve:
The new starting motor from Alanko looks more solid than the Valeo one.
And if the starter motor died a week after you changed the oil you don't have to drain the oil, just remove the oil filter ;)
Jim Green":157hrn8t said:
Does anyone happen a part number or a source of supply for the heat plate shown in picture (top left)?
Mine looks a little bit destroyed after starter have changed the second time.
Jens
