Is the intercooler all I'd need for the stage 1 map?I think with time you will become familiar with the car and box @Ricardo.
I would save the cash and get it read for an intercooler , then a map.
Ill beat you with a stick if you refer to tuning with the word stage again. Let you off just this once.Is the intercooler all I'd need for the stage 1 map?
It was a pre Costa TR postIll beat you with a stick if you refer to tuning with the word stage again. Let you off just this once.
The I/C on the meg is shocking. I would look for one tout suite to minimise the inevitable sky high charge temps.
If you are going that far , grab a 250 turbo as well. So , so much smoother power delivery.I would do the full lot before mapping, intercooler, decat, exhaust (if it does nto already have one) then get it mapped on 630cc injectors. Goes so much better![]()
That's about a grand then, before mapping.I would do the full lot before mapping, intercooler, decat, exhaust (if it does nto already have one) then get it mapped on 630cc injectors. Goes so much better![]()
As you are not getting anything on the display ( I would expect something as well ! ) have you checked fuses ?
Just been reading that it might be an idea to leave it plugged in for 2h as it "pairs" itself to your car. Dont know if that is rhubarb or not.
Yep but there's no way of knowing what digit it's on, you have to scroll through with the wheel I believe but there's no way of knowing... I would have thought it would show 0000 on the display then you scroll though to enter the 4 numbers. Well that's what the Clio display shows... Unless that part of it isn't plugged into the headunit.the code also has to be entered in via the steering controls , not the front fascia.
That's what i'm thinking, only thing is I can't find any other connector at the moment.True.
Sounds like the unit --> display cable isn't connected.
