I don't have much from making up the sills but it was just a lot of guessing and trying to get stuff bent in the vice. I ended up with something reasonably good, for a first attempt and for something people won't see once the skirts are back on.
Here is a selection of the bits I ended up making that need to be welded on. I decided against using the galv piece on the right as it was too heavy, so I made up another piece.
Here is a support piece that was rotten away. I made this up based on the other side. I cut the tabs in so that I could fold the steel over. Will weld them back up.
Installed..
Then I just welded in some other smaller bits, to make up the different skins/panels that were rusted. This is the only real pic I have. This was my second time around welding so I wanted to just get into it..
Next photo then, was of a tacked up sill.. I tacked this and realised I made some mistake (can't remember) so needed to remove it again. It never fit the same after that.. but overall ended up ok, I think.
And the finished product.. minus a few holes that needed another round of the MIG.
.. Before the next panel, I decided to give a shot of Zinc182 zinc primer, followed by paint. Just in an effort to try and seal up the raw metal that was there. Can't hurt.
Don't have complete pic of it welded in, but here it is installed. Note the penetration from the underside.
Ok, pics not in order.. but here you can see the support for the sill. Not welded, but fits "ok" need a bit of finessing prior to weld.
So I slotted the ends of the sill and hammered them over to make it "factory" :lol
I decided to insert a piece of the heavy steel from before, so that I had something sturdy to weld the box iron support to. It's not sexy but will be functional.
Ok, so the photos very hit and miss after this.. but here is the finished product.
Please ignore the massive welds up top. These were plug welds and I wanted to really burn into the next panel, I guess I went a bit too overboard heh! I'll grind them down.
Overall, it's not a totally brutal job. For a first time around making sills, I don't think it's bad at all, as the do remotely line up. Obviously I do think a better job would be needed if the final job was going to be visible.
Still a nice bit of tidying up around the skins where they join up etc.
That's where I am up to now.
