Looking amazing.
I had a Devil exhaust on my 11T. I remember I had to drop the rear beam to get it on as there was no join in the rear section 😩
Funny you mention exhausts… I was having a bit of a sort out in my Garage loft this evening, and found, why I believe to be 2 more exhausts!! Believe 1 to be a GTT, and one an 11 Turbo…!??
If that’s the case, I may be reviewing my choice of exhaust again for the full OE look.?? 🙄🤷🏼‍♂️
Science experiment!
So we’re all well aware of the dreaded faded black plastics & rubber seen on 1980’s cars. The common solution is lashings and lashings of back to black dressing every time you clean the car, but the weather soon washes it off and you’re left at the staring position again..
Well I’ve been giving this matter some thought recently and wondered if there was a different way to solve this problem… a little more permanently. You’re thinking paint..? Well close…
Here are two rear spoilers for my R11 Turbo, and you can see they are already two different shades of black. The top one is the one I’m going to put on my car, but I wanted to have a play with some products on the surplus one, to see if I could improve it:
First step, was to give a small portion of the spoiler a deep clean with a grey scotchbrite pad, and some degreaser/panel wipe. That gave a dramatic improvement, after one pass!
This was where I started the science experiment for real! I did a bit of research, and found that you can dye cured Polyurethane with a solvent dye.. so thanks to eBay, I got a bottle of this Solvent Wood Dye:
I know it’s not wood I’m dying here, but it was the Solvent Dye I needed. Next I painted on a layer with a foam brush, and spread it evenly over the section I was testing on:
Next it was a few minutes under the garage fan heater:
Before a final inspection to see what the results were like:
I repeated the dying process 3 times in total and the final comparison is this:
I think this could be a REAL Winner for my final choice spoiler..! Will give it a few tests over coming days to check that the dye doesn’t run off in the rain etc… but if that works, then I’m onto a winner for a brand new OE looking spoiler, without the greasy covered in back-to-black look!! 👀
Thanks for having a gander!!
24th February 2022, The day Russia 🇷🇺 invaded Ukraine 🇺🇦
Nothing stops getting Project Renault 11 Turbo back together!! 🙄
Been working on the offside of the car over the last few evenings, and tonight I finally got the bump strips on the side of the car.
Same process as the Nearside, apply the red decal onto the bump strip, then 3M Moulding tape on, then finally stick it to the car.
As I had all the fastenings on the front strip that goes onto the wing, I started there, and then worked backwards:
And finished at the rear quarter panel:
Side skirt next 👍
Interior Refit Begins ⤵️
Started on the drivers door this morning.
First I dug out the wing mirror, and fitted that:
Next it was to fit the horrible sticky mastic glue:
Then the rain guard I previously scraped all the old manky glue off 😩:
Then finally time for the door panel. Dug out all the new OE clips I ordered as the old ones were in various stages of horribleness:
Then the panel goes on:
Before the door handles and door pocket! ALL DONE!
Then I moved onto the rear quarter panel, covering the Amplifier. First was the lower fabric trim:
Then upper trim:
Chuffed to bits how it’s looking:
Makes me laugh how a few pictures on here make it look like 5 minutes work, but it took most of the day, groping round finding all the bits in various places, and then finagling everything To make sure everything fits absolutely spot bollock on!
Buoyed by the success on the drivers side, I moved to the passenger side rear quarter, which went on really quickly after doing the drivers side. Lower trims on first:
Then upper:
BOOOOOOOOM 💥
