Had a couple of hours in the Garage on Saturday continuing to go through the piles of parts I have and picking out the best ones. Sometimes is hard to decide which one is the best one when they both look totally knackered, get a load of the two spare wheel brackets I have..
So I was planning on replacing the complete front suspension set up with a R19 16v Set Up (like I have done with the rear axle), but I spent a few minutes comparing the two subframes I have at the weekend I noticed there were indeed more differences than the first glance. (Apologies I didn't have my camera with me at the time, so cannot show you the differences; I will do in the future).Therefore I decided to stick with the original R11 Subframe, but where the heck am I going to get another one of those in a hurry...? Well thankfully the one I took off the Red 11 Turbo I broke some time ago, although looking rusty, was still sound, and I thought It could be brought back to life:
There bottom is all very straight, and doesn't look as though it's been through the whole pikey Kwik Fit Jacking process, so just the job for my car. Just the matter of it's current condition....
So after a little bit of homework today I've decided to give it a bit of a birthday and have dropped it off at a Blasters to get all of the old paint/rust/detritus off. My plan is then to get it Galvanized to protect against the future corrosion; and then powder-coated on-top to give it the nice finish/shine I'm looking for with this car.. I should be getting it back from the blasters this Friday, so will post an update for you all to show you the progress. Note the colour of the subframe isn't the usual Black of the R5, but a rather interesting Grey/Silver? I believe this to be the correct colour for the item as the original subframe from the Silver 11 is Grey as well. This is something I plan to keep during the restoration, and add to as I think It will go well with the Silver paintwork of the rest of the car
I've had a few more eBay purchases of late, and last week took a gamble on a brand new Renault Servo for £30, that the seller didn't know what car it was for. I read on a R19 Forum, that one of the common upgrades for the R19 16V is to replace the servo with a Kangoo one for a better brake feel..
The brakes on this car have always been pretty
even though I repaired/replaced a lot of the stuff prior to the rebuild to improve them but it never achieved the required result, so I promised myself that I would do everything I could to improve them during the re-build! When I compared this new servo to one of my Original R11 units you can see there are some small differences:
- The new servo is 20mm bigger in Diameter (I hope it fits the space on the bulkhead, can't check until I get the car back from the Dippers)
- The actuation fork is a lot longer, with no adjustment (I think an accurate drilling will sort this)
- They both appear to be the same depth (Good!)
- The 4 fixing bolts on the inner face are more closely spaced (Again I think an accurate re-drilling of the mounting bracket will fix this)
So I have some questions for all you clever car blokes and would appreciate your input:
- What Impact will fitting a new larger Servo to the OE 19.1mm Master Cylinder have?
- What Impact will fitting this new larger servo AND a 20.1mm Master Cylinder (OE Supply to the R19 16v, don't forget I've fitted larger R19 16v Brake Disks and calipers to the car)
- What would you try??
- Can anyone tell me how a Servo Works?? When I measure where the actuator rod is in relation to the actuator in the Master Cylinder, It appears they're something like 20mm apart...?
Thanks for reading
