I've been doing some research on the old interweb (little Gas Monkey Garage reference
) about what products to use on the car and found out that a Monthly Classic Car Magazine have done a 3 year test on anti-rust paint (and cavity wax) and the results are now in!
I managed to download a copy of the report to share with you as it makes for interesting reading, as one of the products that I've always been a fan of and actually used on my Raider (POR-15) came LAST in the test!!
You can see that the winner of the test for the external coating was RustBuster Epoxy Mastic 121 and is one of the products sold in the UK on the
RUSTBUSTER website.
I read the information on the website and realised that they're not a million miles away from Peterborough (in Spalding) so again I thought I would have a ride over there and have a chat with the guy face to face:
I ended up walking away with a Chassis Pack of the Epoxy 121 in Aluminium Colour to hopefully match in with the final Silver colour the car will be painted in:
So now I've got the stuff to make a start on the underside of the car, I had half a day in the garage today and got stuck in! As I'd mentioned before I found a few bits that were a bit scabby following the sheep dip:
Ian (the guy at RustBuster) recommended that I used a wire brush to remove the loose paint and rust from the scabby areas, then over paint them directly with the Epoxy 121. He also recommended to paint all the seams and metal edges in the Epoxy 121 BEFORE I seam sealed them to ensure that there was no rust allowed to grow under the seam sealer.
I decided to split the car down into smaller sections to work on, rather than tackling it all in one fell swoop, so this was today's section to work on:
I used a selection of wire wheels in a drill to clean up all the area's and also had to scrape a few points with a screwdriver. The Epoxy 121 comes in 2 parts, and you have to mix them 1:1. I bought myself a load of mixing cups and small disposable brushes to make this job easier. I mixed just 120ml (60ml of both parts) of the 121 to take my first steps with this product:
The 121 went on quite well. It came with some thinners, but I didn't feel the need to thin it down. Here you can see I painted all of the seams & scabby bits I'd rubbed down. The plan is to then clean and paint the other sections of the underside of the car with the 121, and then I'm looking to spray the whole lot for the final finish.
Thanks for reading
